ccarley
Hey guys,
Been a while. Family, job, house... things like that, you know?
Anyway, my Suburban has developed significant play/ wander in the steering area. I've gone through and checked the wheel bearings, all the ball joints are tight, tie-rod is tight, and I replaced both ends of the drag link (tie-rod?) from the steering box to the axle. Oh yes, and replaced the steering box with a good tight unit from the junkyard.
So, the steering feels tight if the truck isn't moving, but once you start going 5mph or more, there's about 5 inches of play at times in the wheel. More details: I do have ORD's swaybar disconnects, Tuff Country H.D. springs, and Bilstein 7100 shocks up there. The ride is soft (i.e. the suspension moves a lot).
I found last week that the driver side shackle on the front spring basically has no bushing at the frame, and is creaking badly and can move wherever it wants pretty much. So, I ordered ORD's heavy duty shackles & bushings, and while I was there, also ordered the bolt-in steering box brace. If this stuff doesn't help... I guess I'll order up a tie rod from them with new ends... but man the steering shouldn't suck this much! I was tempted to put in yet another steering box, but I really don't think that's the problem.
Can / will worn shackle bushings cause odd wandery steering issues? It's a super hard thing to search for... believe me I've been doing it all week!
Clay
Clay
