Front spring center bolt {pin}
xflatrater
Shamong NJ
Can someone measure the center bolt if you have an old set of springs lying around? I need the bolt diameter and the pin diameter for custom steel caster shims.
Thanks!
i have an old stock set from my 86. the center pin dia is 9/32nds. the nut is 1/2 inch and the the center pin head is also 1/2 inch...
Mine are all 3/8" fine thread and take a 9/16" socket. Just worked on the springs about 2 hrs ago /forums/images/graemlins/grin.gif
A 3/8" socket hd cap screw is usually what works, someone corect me if Im wrong.
