I ended up getting a screw extractor bit, actually two, from Sears, but they were no help. Stopped at Autozone to get price on bearings and hub...ouch! I ended up buying a Haynes manual out of frustration. Brought it home and realized it really didn't help me in trying to get that one side back together.
There is a washer and snap ring I can't recall where it went on and the book doesn't even show it. I though the washer went on right after the inner spindle nut, followed by the snap ring then the outer spindle net, but it wasn't happening.
And the book isn't really clear about how the coil spring and retraining ring goes back on. That's why I wanted to look at the other side, but obviously no progress there.
I was drilling the heck out one of the screw heads, but wasn't making much progress. Can I cut the screw heads off with a cutting tool enough to get the cover off? Hopefully if so, I can have enough of the screw studs exposed to spin back out.
Also, I noticed there is more play in the side with the cap issue. Hopefully I can tighten it up like I did the other side, because I don't have the budget now to get all those new parts.... and I’m worried I am going to pay someone (labor) to fix my mess.
