- Joined
- Dec 13, 2016
- Posts
- 100
- Reaction score
- 226
So kind of odd question here but looking for some thoughts/ input. The trany in my daily, 98 silverado 3500, is on its way out. Found lots of metal shavings in the pan. I need to get our 05 Tahoe here to replace it while I fix it.
Problem is, the Tahoe is 220 miles away and has a rear end whine, guessing pinion or carrier bearings but haven't been able to dig into it yet. My thought was to remove the rear drive shaft, tape off the tailshaft so the oil stays in, and drive it home with front wheel drive. Would remove the rear drive shaft to reduce load on the rear end.
My main concern is the transfer case not being up for that and getting too hot or causing some problem with it. Any thoughts/ input/ experience with doing this would be great. Was planning to trailer the Tahoe back but after seeing the shavings in the pan I'm not risking that.
