FS: 10b front axle 8-lug outer
blasphemous
Louisville, KY
I have a 10b front that I was going to run, however I decided to go bigger and badder (picking up a D60 this weekend). I already converted it to 8-lug outers and has BRAND NEW Timken bearings and races in the hubs. The rotors have been replaced and are brand new. The old wheel studs were pressed back in, the threads are fine. The axle itself is 3.08 open, small bearing hubs/spindles.
I have over $85 just in bearings and rotors. The hubs are for the large external lockouts. I have a set, but they're not in the greatest shape. Useable, just not very pretty... Warn hubs I believe, missing bolt to mount them to the hubs.
It has the 3/4 ton backing plates on it, sanded and painted. I also have a set of calipers, but they're probably just cores. I haven't checked them at all. I'd like to get $250 for the entire axle, it's open to OBO though. May be open to trades for following items...
-4' (or longer) pieces of 1.5" OD DOM tubing, .250" wall
-4.56 14bFF gears (4.10 down carrier) or 4.56 gears AND carrier
-2WD steering box
-1-ton TRE reamer
-NP205 SYE parts
-Oldsmobile heads (big block)
-BOP bell housing
-1-ton U-bolts (longer than stock)
-Saddle/transfer tank larger than 50 gallons
i might be interested in the outers. you have everything to convert from 6 lug?
Oh, and I still have that van if you're interested...:laugh:
A buddy actually unloaded a car on me for the same price. Couldn't pass it up for a few reasons. Everything is there to convert from 6 to 8 lug. I just picked up a D60, so I'm not using it anymore.
my interest has been resparked... I am still working on that frame for you and will be in touch.
You going to 3/4's? I've had a few "leads", but nothing's come through so far... locally.
BizeeB65 said:
yea, I got a lead on a CHEEP 14BFF... So if that comes through, I will be calling you.
Alright, I'm going to get out to the garage in the next couple of days to check out that 12b too. Also, if you know anyone with a K-series truck frame too, I could use that also. Shortbed preferred, but I could cut down a longbed frame.
