lak2004
I have a 1985 Chevy K5 Blazer for sale.
The title is available once funds are sent to my bank, the title will be sent to you. You can talk to them to verify this if you would like. Im not trying to screw anyone.
It is a project truck and either needs a little work to be road/trail worthy or you can use it as parts.
Engine: Fuel Injected TBI 350, heads are from a 305 and have had work done to them. There is an aftermarket cam as well. It has a set of Hedman Headers on it and a high torque mini starter.
Transmission: 700r4 with a shift kit. I have a Corvette servo I can give you for it that makes the shifts more firm.
Transfer Case: NP208, needs a new mount which I will include
Axles: 10 bolts front and rear with 3.73 gears. Front tie rod is from ORD and is 1.5” DOM Tubing. The tires are 35”x10.5x15 BFG Mud Terrains. Fronts are worn and cracked, rears have good tread but are weathered. The wheels are Mickey Thompson Classic IIs.
Suspension: 6” Procomp lift front and rear all spring NO BLOCKS! Pro comp shocks and steering stabilizer. Poly bushings on all springs
Body: I have cut up the fenders and abused the rest of the truck somewhat. The passenger door was dented in by a boulder and the rear tailgate is shot. The window is off track and you basically would need a new tail gate. The front inner fenders were taken out a long time ago and the battery was relocated to the firewall.
This is a project vehicle, you will need to bring a trailer to take it home. I can possibly help deliver within 50 miles. If you have any questions please feel free to email or call. Thanks
I am located in Durango, CO and asking $1200 OBO
