FS Holley FI 504-21 closed loop
norville
A stones throw from Pargon Mountaintop Pa
Folks I'm selling this used FI Kit I bought a few months ago. I had it on my truck and my laptop died. I need the truck and pulled the system before I got it all tuned in. All is there like new. Come with an O2 sensor for closed loop running. I have a weld in bung and a dynomax 3"-2 1/2" reducer also. It only took about 3 hours to install and have it running. You will need the small prefilter for the fuel pump. Laptop in pic is not included you can have it for $25 more shipped (the cmos battery is dead) I can get more pics if needed.
$650 shipped.
504-21 4 BBL DIGITAL INTERACTIVE FUEL INJECTION SYSTEM FOR 350-500 HORSEPOWER V-8 NON-COMPUTERIZED ENGINES. 900 CFM, 4 BBL. THROTTLE BODY WITH (4) 85PPH INJECTORS. IBM COMPATIBLE, PC PREOGRAMMABLE FOR FUEL AND IGNITION CONTROL. FITS MOST 4 BBL. STOCK AND AFTERMARKET AIR CLEANER SYSTEMS. INCLUDES: 4 BBL. TBI ASSEMBLY, DIGITAL ELECTRONIC CONTROL UNIT, 410 GPH ELECTRIC FUEL PUMP, COMPLETE WIRING HARNESS, SENSORS FOR COOLANT TEMP MAP OXYGEN AND AIRCHARGE TEMP. THROTTLE POSITION AND AN IDLE AIR CONTROL MOTOR. 3 1/2" SOFTWARE DISKETTES, MOUNTING HARDWARE AND LINKAGE CONNECTIONS(some of it) EASY TO FOLLOW INSTRUCTIONS. GM KNOCK SENSOR COMPATIBLE. REQUIRES P/N 20-98 BRACKET FOR USE WITH GM TH700R-4 TRANSMISSIONS. NOT COMPATIBLE WITH OTHER AOD TRANSMISSIONS. REQUIRES GM OR FORD 7 WIRE DISTRIBUTOR FOR IGNITION CONTROL. NOT LEGAL FOR SALE OR USE ON CALIFORNIA POLLUTION CONTROLLED MOTOR VEHICLES.
Similar kits like this sell for $1500 new, I'm asking $650 shipped with extra software.
you bet... I had this on my "big block" ford warm 390...
This will bolt up to any square bore 4bbl manifold or you can get an adapter if the manifold is for a spreadbore.
PM coming w/number if you need more info.
bob
