yeah, that foam junk is crap. doesnt seem to do much other than cause problems with normal pump gas. /forums/images/graemlins/frown.gif
Something in the formulation of modern pump fuels attacks the foam. If you take the foam out, then you no longer have any baffling and will experience starvation issues when at an angle.
The problem is that when you buy a cheap fuel cell you get cheap foam. Step up to an ATL or Fuel Safe cell and you'll get much higher quality foam. Even then the foam does have a definite life span.
