Just replaced the tank, straps, sending unit and all fuel lines on my 89 TBI Jimmy. The tank isn't fully in yet, still have to hook up the evap line and filler hoses, but I wanted to see if the gauge would move if I plugged in the sending unit and ground wire.
Some background info; when I got the truck, the fuel gauge was pegged at 9 o'clock, way past empty. Took the gauge cluster out and found out the circuit board was fried on the return connection from the fuel gauge. Once I replaced it, it moved all the way over past full, around 3 o'clock.
From there, I figured it had to do with the sending unit or the wiring to the unit. Found the ground bolt and wire from the sending unit, sanded the frame down around the bolt hole and still no luck. When I dropped the tank and saw the sending unit, the ground wire was pretty corroded at sending unit end. Figured that was the problem.
So with a new ground bolt and new sending unit, still having the same issue. I know there is a pink wire that comes out of the connector where the sending unit plugs in and runs down the frame to the front, but I lose it right near the front door and rocker, maybe that's the issue? Also read online somewhere that the fuel system and oil pressure switch are somehow connected; my oil pressure gauge always reads high (almost always between 45-60 psi, no matter what), wondering if that has something to do with it. Can't find any info in the 87-91 service manuals on how to troubleshoot this.
the bed,now it just pegs the gauge at 3 o'clock like yours..
