87 K5 w/tbi.....truck will start fine...and idle fine...when you give it a little throttle, it boggles down and wants to die...also wants to die if put in gear. Passenger side fuel injector has a cone shape spray, driver side does not...If I swap electrical connections, driver side injector has cone spray, passenger side does not. I used a timing light to get a good view of the cone spray. What the heck is going on...both fuel injectors are new...so is fuel pump and fuel filter.?
It does have the heavy exhaust smell and light smoke from the tailpipe (sometimes). will timing do this?
You are seeing a physical problem that needs cured. If it's not spraying right, it's likely not burning right either, which would cause symptoms you describe.
Thanks for all the help from everyone.
Wheels
I'll do the noid test after work tomorrow and see what happens. Thanks again.
