Here's why the light trick won't always work when testing fuel injectors. The injectors are pulsed, which to them is turning on and off. To a slow responding item like a light bulb, this is like a DC voltage. At idle your pulse width is low, so the duty cycle is maybe 10%. To the bulb this looks like 10% of the supply voltage, which is 1.3 Volts or so, which might not produce any visible light.
So at low rpm / low load (i.e. idle), you could measure from the injector low pin (ECM side) to ground. Instead of 10% of supply voltage, it would be 90%. So it seems like you could see the bulb "dim" slightly when the injector starts pulsing. Unfortunately, the supply voltage is also changing when you start the engine.
Plus, if you're going to hang something from the ECM injector drivers, you should make sure it is a small bulb. You don't want to burn that out or prevent the injectors from opening properly.
An oscilloscope is the best option. If you don't have one of those, try an analog meter. The thing is, if you unplug the injector to do the test you change the conditions. You lose your "pull-up" to B+ as well as the circuit load (an injector is Ohms and a multimeter is Millions of Ohms). You should see a low voltage which increases with rpm (voltage is proportional to duty cycle). Also, blipping the throttle should make the voltage spike up a little due to acceleration enrichment.
