KRAZIE87K5
Right... that is not the ECM. What you have there controls the knock sensor. The ECM is under your dash, kind of up above the glove box. Its a silver box, and has MANY more wires /forums/images/graemlins/wink.gif Looks like this.
You need power to the ECM to get the fuel pump to run. You need switched power on pin A6, constant power on pin B1 and ground on D1. If you have this, you have power to the ECM. See this chart for more information.
Hope this helps man... sorry its so complicated.
-Dan
-Dan
