Wanted Fuel Tank GMT400 suburban
Maybe it's something to do with the actual address, rather than just a blanket zip code.
I'd get the part number off rock auto and check Amazon if you use them. The price was actually neat the same iirc. :dunno:
I figured it out @mrk5 And I were selecting the cheapest fuel tank at $137, if you select the Spectra tank $142 shipping picses change. I'm guessing it's due to warehouse location.
I might end up buying a new one. People here are wanting 130 175 or highest 200 for their fuel tanks with me pulling it! Everyone is on crack apparently
This being a low buck wheeler how about buying a tank from the wrecking yard, running a self tapping bolt in the hole they punch and then run a bead around the bolt head?
Taking all the safety precautions of course.
Eh., $180 for a new one to your door with no rust is great insurance... Last thing anyone wants is a fuel leak..... Fire is bad lol.
I took one out of my burb with what looked like surface rust. Hadn't been leaking that I could tell. Used a scotch brite to clean it up and found 2 pin holes.
I been thinking of repair what I have. Has a few pin holes from rust. Might try some tank repair junk. Next trip will be in February so I will keep a look out on marketplace for a deal. If nothing is found I'll buy a new tank
from a born and raised and worked in rust belt guy ..... new tank .
i just scrapped a 22k mile gm tank cause of min rust on the outside but 10-12 pin holes showing ready to pop on the inside after the sender was pulled to check it .
Yeah... Gas burns things down. Leaks suck lol
Unfortunately not in Denver but if you can get it there cheap I have a 40 gal in northern California $50
I just might be able to have the tank shippd threw work. Can you send me you zip and vox size and weight. If it works out I will send you a shipping label
I will send you the size. Zip is 95648
You probably can get an idea on the weight from rock auto.
I am pulling it out after new years.
Yes I will guess 40 pounds probably be good. Work never asks for size of box only the weight. But I want to size incase they ask. Consider it sold. After new years is fine. One you got it boxed up I can get you a shipping label just print out slap that bad boy on and it will be shipping threw ups. Merry Christmas
You got it
