Crazy!!
wonder what would happen if someone else ordered it and had it shipped to you?
This being a low buck wheeler how about buying a tank from the wrecking yard, running a self tapping bolt in the hole they punch and then run a bead around the bolt head?
Taking all the safety precautions of course.
I just might be able to have the tank shippd threw work. Can you send me you zip and vox size and weight. If it works out I will send you a shipping labelUnfortunately not in Denver but if you can get it there cheap I have a 40 gal in northern California $50
I will send you the size. Zip is 95648I just might be able to have the tank shippd threw work. Can you send me you zip and vox size and weight. If it works out I will send you a shipping label
You got itYes I will guess 40 pounds probably be good. Work never asks for size of box only the weight. But I want to size incase they ask. Consider it sold. After new years is fine. One you got it boxed up I can get you a shipping label just print out slap that bad boy on and it will be shipping threw ups. Merry Christmas
What year suburban are you pulling parts from? Will also need a good A/c line for 1995 and newer coming off the compressorYou got it
