What did you use to measure when cutting the A pillars? Is there a seam or common locator I've missed? With the top of the frame being curved there doesn't seem to be a good point to measure down from.
What about the doors? Cut the top even with the vent window frame? The lower door cut appears to be higher that the bedside, no?
I don't have a top or donor doors to use and the tech article is good but there's no specifics about locating the cuts.
