The car dealership
I did put a new one in but might be lower quality. Ebay.I removed flywheel cover and it's all dry there. Then did little experiment - I hung long stripes of rags off different spots around transmission pan. It's like @imiceman44 said. Leaking from TV cable base. There's some silicon around it already but apparently doesn't help.
How do I proceed? Remove TV cable and put the new one in? Do I need to drop the transmission pan?
I was just watching this video
at 2:59 the guy says that the new transmission comes with rubber seal for TV cable. Then he says brand new TV cables also come with the rubber seal and that ONLY ONE seal is needed. On the video he removes the seal from TV cable. @imiceman44 - would you know if there is 1 seal or 2?
Also, would you know if it's TH350 TV cable or 700R4 TV cable? I hear they are slightly different.
The new TV cable (ACDelco 25521268) should arrive tomorrow. I will try to change it myself. How do I keep the hook that's inside the transmission so it doesn't retract back? Also, if I lose that hook - can I still retrieve it without dropping the pan?I did put a new one in but might be lower quality. Ebay.
It was fine until I got the truck back from the shop.
Now I am thinking maybe the pan gasket might have been fine.
If you get the new tv cable I can swing by and help you with it, it's tricky not hard so if you have done it before it is easier
That hook will not drop.The new TV cable (ACDelco 25521268) should arrive tomorrow. I will try to change it myself. How do I keep the hook that's inside the transmission so it doesn't retract back? Also, if I lose that hook - can I still retrieve it without dropping the pan?
It's adjustable. That big "D" shaped button on the side of the housing is how you adjust it.
I didn't notice that, how close is it really.Those cooler lines are close to the exhaust eh? Might think about some heat sleeves so you're not cooking the ATF in/out of the trans.
It looks like a couple of inches which will be fine but if it's less than an inch away it needs to move
Oh if it was my truck and I had the time I would wrap it but I also would route things differently.Matter of opinion perhaps but that would be wrapped if it was my truck.
