'91 tbi K5 350 stock, 700/241
Went wheelin' yesterday and about 3 hours into it, it started idling rough and no power what so ever, hit the gas and it souded like I had the rev limiter set to 900rpm. Check engine light was on (haven't scanned it yet) Shut it off and restarted it and it idled and ran fine no CEL, then about a 1/2 hour later same thing but without the CEL
. Tank is inside the truck and when it starts to idle rough I don't hear the pump change pitch at all ( blew 2 fuel pumps because of crap in the tank so I listen very carefully to that now)
Put it on the trailer and when i got home (2 hours later) started it up and ran fine.
Any ideas on where to start looking. Not sure if any codes will be there when I scan it.
Tanks for the help in advance
. Tank is inside the truck and when it starts to idle rough I don't hear the pump change pitch at all ( blew 2 fuel pumps because of crap in the tank so I listen very carefully to that now)Put it on the trailer and when i got home (2 hours later) started it up and ran fine.
