Fuse or fuse and relay for trans cooling fan.
cuervo
Runn'n down a dream!
Sweet Home Alabama!
Throw a multimeter between it and the battery to determine your amps. Relays are never a bad thing but depending on where you are installing it and drawing power from might be overkill
Well, it calls for a 15 amp fuse so it has to be less then that. The run from the 12v source will be less then 2 feet. I'm going to go with overkill and leave the relay out.
Are you running a temp switch or manual switch?
Also, it notes 6 amps and I would run a relay.
God I hope you didn't pay that much for it......rip off! Yes I would run a relay to anything that's not off the fuse block. I run on my tranny fan as well.
Well the thermal switch that came with the cooler isn't doing me right. Trans temp gets to over 200 before the fan kicks on. So, I'm going to add one of these to the line out right before the radiator.
https://www.summitracing.com/parts/DER-35020
I also installed the relay right next to the rad where this switch will go.
Thanks for the input. It's always appreciated.
Not sure how you're all plumbed and where your temp sensor is however it's not uncommon to have gauge reading much different than the fan switch. I would test the switch in a pot of water with an ohm meter and a temp gauge first.
I have my sensor & gauge plumbed in right inline right next to each other. But yes it's best to test to make sure there in the same ball part of each other.....
The temp gauge sensor is drilled and tapped into the side of the aluminum pan. The sensor is, well, right on the fan. I may just opt to run the fan relay to a keyed hot and be done with that part of this.
