fuses
K5Blazer28
Wyoming
has anyone blow fuses from having your electrical towing connection submerged in water ?
I have never seen it happen, but it could be possible. Basically since you have both a ground and a power there, it is possible the water could provide enough of a path to pop a fuse.
Biggest thing I've been warned about is unplugging connections for electric brakes before submerging. Lights aren't usually a problem.
problem typically in my experience has been a crack in the tail light lens. This allows water in the casing and allows for a short. could also be a frayed wire touching water and popping fuses. Check for loose wires and the tail lights. Hope this helps.
