Crack repair...Sika Anchorfix 1 or 2, Sika Crackfix, ports and cork stoppers ( Will need one of each ever 4" - 6")
Glue the ports ( Every 4" x 6" ) and seal the outside of the crack with the Anchorfix.
Let dry
Inject the Crackfix starting from the bottom most port until it comes out the next port up
Seal the port you just injected with a cork stopper.
Continue injecting the next port up.
Let dry
Scrap off the ports and any excesses Anchorfix
Done
All the above epoxy come in 10oz tubes so all you need is a caulk gun.
If you can't find them, let me know and I can send some your way.
I would dowel the existing slap using 1/2" or 5/8" dowels and epoxy them in with the Anchorfix from from the crack repair.
You probably don't need to use any kind of bonding agent between the two...But it's cheap insurance... Just don't let it dry, it becomes a debonder when dry ( Unless you get the rewettable type )
The plastic under the concrete acts as a water barrier to stop the ground sucking the water out of the concrete letting it dry slower ( Something you want ) It also acts as a vapor barrier.
As far as expansion joint I would use the fiber type with a removable cap then a good quality caulk. That works the best for stopping water getting down into the joint. My next best is the rubber type, it lasts for ever but there's a chance it will let water by. The last one is just using the fiber type, it will last a couple of years before falling apart and your right back to where you are today.
Let dry
Let dry
Done
