So.... I finally am going to fix the sagging concrete apron at the front of the garage. Charlie and I rented a 90LB jackhammer and had more "fun" in one-day than I've had in a while!!
The garage was built sometime in the late 50's / early 60's, and as far as I know the floor is original. It was poured with a slight angle from the back wall toward the doors (maybe 1" per 8 feet?) and there is a separate perimeter foundation that holds up the sidewalls and the spot between the rollup doors.
The base material looks like regular sand, there was NO wire mesh, or rebar... which made removal easier, but I don't think that's code anymore. Also, the cement thickness was generally about 4-5" inches thick in the pad, but almost 12" thick at the apron itself!!!
Over time, it appears that water has been undercutting the foundation and caused the pad to lose it's support. It eventually cracked about 3' inside each of the doorways. On the left side it is a long diagonal crack, and on the right side doorway it is basically parallel to the roll-up door.
Here is a MSPaint, showing where the cracking is... and where I will need to repour the cement.
This is the "end of the day" shot showing the excavation of the concrete and the resulting space that needs to be repoured.
So I have a few questions about products / methods to get this done correctly:
1. There is a 1/2" crack in the perimeter wall near the front corner of the garage (where the pad settling was at it's worst). I've now got good access from the inside/outside to inject an epoxy of some kind to keep water out and strengthen in back up. What product is good for that?
2. Should I drill the remaining concrete and run rebar into the holes to help insure that the new pad stays bonded and "locked" to the old stuff? Should I epoxy the rebar in each hole, or will it be good enough to just run the bar in maybe 4" - 6" and then pour cement over it?
3. What size rebar "grid" is correct? I want to run rebar in both directions and then space them up with dobie blocks, since that seems to be the standard method I've seen used.
4. Plastic sheeting - Do I put plastic under the whole mess before pouring concrete or no? Not sure if that adds value or not for a garage space.
5. What is that "horsehair" looking stuff that is used between the concrete and the sidewalls / asphalt to act as an expansion joint? Is that the correct material to use, or is there something better?
6. Adhesion Promoter? - Will new concrete stick to the old broken edge or do I need to prep that area to get a good bond?
I'm sure there's more, but I wanted to start soliciting feedback from guys who to concrete work, and/or understand the process since I've never done anything of this scale before. I've set a few posts in Sonotubes, etc. But everything has hand-mixed and didn't require much thought or pre-planning.
Thanks!
-G
Thanks!
-G
..the water simply flows right over the driveway now too,I guess the pipe either was squashed by the roller,or simply clogged up after a year or so with silt..
