I have a 1974 Jimmy and every time I fill it up, I have to pump the gas very slowly and even then it often overfills and runs down the side of the truck. This weekend, I will check the vent pipe for obstruction, but based on the threads I have seen, it seems that this is a common issue with the California gas pumps and trucks of my vintage. But just looking at the aftermarket fuel filler necks, it seems that the design of the 1979-1991 trucks is much better (the neck angle makes more sense).
I was thinking of simply changing out my filler neck (and maybe the tank if necessary) and putting in a 1982-1991 system. The 1982-1991 has a wider neck so should handle higher gas flow. Has anyone ever done this? What I don't know is what the area around the gas cap opening (behind the filler door) looks like. I would appreciate it if someone could take a picture and share it. Obviously in my year, there was no filler door and the gas cap is flush with the body. I am assuming the later years the gas is angled like you see in modern cars.
I am just sick and tired of the hassles getting gas into my truck (not to mention what spilled gas does to the paint job!)
Thanks in advance for any help you can provide.
