Gas tank access
Those "bed repair panels" for pickups may work,if the ribs are spaced the same on a K5 ,for a "patch" ,if you cant find a donor truck at a boneyard..(I'm not sure if K5's and Suburbans bed floors are the same panels a pickup uses )..
Burbs and blazers are the same. I used panel I cut out of blazer for burb access panel. I think trucks are the same but not 100%
