thealien
The PO installed an aftermarket 30+ gallon gas tank in my Jimmy. During the installation they actually cut a 4 inch diameter hole in the floor about where the sending unit is
!! I am going to patch the hole and put an aftermarket/stock tank in.
I keep reading that the filler neck on these need to be replaced with the one from the stock tank to make them work/not hit the body mount. Anyone have an old gas tank they would cut off the filler neck from leaving the two bolts and flange so I can put a correct gas tank in and sell it to me?
TIA
Mark
I need this for a 1969-1972 tank
!! I am going to patch the hole and put an aftermarket/stock tank in.I keep reading that the filler neck on these need to be replaced with the one from the stock tank to make them work/not hit the body mount. Anyone have an old gas tank they would cut off the filler neck from leaving the two bolts and flange so I can put a correct gas tank in and sell it to me?
TIA
Mark
