Gasket source for fuel tank filler neck "shield"?
dyeager535
1 ton status
Solutions
1
Roy, Washington
I know this is a very niche product, but GM apparently doesn't sell them, and I had to actually replace the shield. This is the piece inside the bed on the K5 behind the passenger side wheelwell.
Just wondering if anyone knows of a source for this thing. As my truck proved, this is a very critical piece, if the seal leaks, it rots the truck out in that area.
For those that don't know what the piece looks like, it has a 90* bend where the bed meets the bedside, so making a gasket would be fairly complex.
If no source, I'll RTV it, but if I ever have to pull it again, it will be hard to get out. Even with the stock foam gasket the old shield bent trying to pry it off the truck, I can't imagine how fun RTV would make the job.
I just used some Fusor self-leveling seam sealer. worked great. Any seam sealer will work. The self leveling sealer flows a little nicer and makes for nicer presentation (like that has ever mattered to me LOL)
Chris
Filler neck Gasket
The part number from LMC is 32-3332 and it costs 9.95...then add shipping. I have my catalog here at work so I can look at parts and list what I need...I have the 05 Spring edition BZC.18 catalog. You need to have that info if you order online.
Thanks for the number/price.
Seems pretty pricey, tube of sealant is probably half their before shipping price. :)
I got both pieces from the stealership a couple of years ago when I swapped tubs. IIRC the gasket was more than the sheetmetal :crazy:
James
Maybe that was it...I didn't feel that a gasket was worth more than the piece it seals. :) Been a year or so since I checked.
Sealant of some type is probably the best bet at keeping that joint from leaking, I painted over the stock paint to hopefully give it some more protection in the first place.
I've got some butyl tape, but my feeling on using it (or that urethane I suspect) is that if I've ever got to get that thing off again, I'd NEVER be able to clean it up or seperate it without a huge hassel.
What about the white foam sealant in a can from DAP. You can spray it on and then when it dries trim the edges with a sharp utility knife.
