Gear ratio????
55Willy
3/4 ton status
Keizer, Or
I pulled the cover on the 14 FF and heres the numbers:
2 GM 3992484 11 41 9 77
is it 41 / 9 for 4.56's ?
or 41 / 11 for 3.73's ?
<font color=red>Life is like a mud hole:</font color=red><font color=blue>
When the S#!T gets deep, you have to keep moving and friends can always pull you out</font color=blue>
55 Willy's
I think it's 77 / 9 for 8.56's
<font color=blue>It's easier to teach a child than to fix an adult.</font color=blue>
<a target="_blank" href=http://community.webshots.com/user/geltyone>Webshots Pics.</a>
I *think* its 41/11 for 3.73's, manufactured in 9 (Sept) of '77.
Mine was much like that on my Dana 60 ring gear..........mine was built in '78..............
<font color=blue>'79 ONE TON TPI K5 - See it at---&gt;<a target="_blank" href=http://www.blazzinor.rockcrawler.com>www.blazzinor.rockcrawler.com</a>
Yes, as another confirmation, its 41/11 or 3.73
Brian
Check out <a target="_blank" href=http://tx85gmcguy.alloffroad.com>My Jimmy</a> with all her projects!
So what kinda tires am I looking at running, I have a sm465?
55 Willy's
Jeremy...I run 36's with 3.73's and a SM 465. It's not that bad, a hair 'tall' for the street but it wheel's just fine. My cruise RPM is about 2500 (70 mph)on the freeway.
Rene
<font color=green>Dyslexics of the world...UNTIE!</font color=green>
<a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
And I thought everyone said you were short
Just messing with ya
Anyways by "tall" are you talking tires or gears. I assume gears and that RPM's are a little to high for the street. In that case just get a "tall"er lift and "tall"er tires and rpms with drop
See my rig at <a target="_blank" href=http://coloradok5.com/gallery/Leadfoot>http://coloradok5.com/gallery/Leadfoot</a>
Well 4.10's would be perfect for the 36's and the 4 speed. No sense in makin the swap from 3.73's though.
The gears are a bit tall for the tire size. With a better clutch I'd prolly not notice as much but my clutch chatters a bit. Personally I think the cruise rpm on the freeway is close to ideal.
Rene
