muddy shoes
i have a 350/dm465/np205 and im currently running 35"tires and going up to around 38s, will 4.56 gears be enough for weekend offroading and dding? if not what should i look into.
you never here about my gears are to steep only they are not enough, my opinion i would get 4.88 you will eventually want bigger tires so gear now for them.
I dont have a d70 wish i did if i did i would not be selling it, im in oc if ya want a ride in a 465 205 truck on 42 with 4:11 or 4:56 stock and it aint enough, i had 39.5 iroks before the 42 iroks. It had a 350 smog motor in it with a edelbrock intake and holley, it ran good, swapped to a mid big block runs better especially on the freeway but i want mid 5.38 gearing atleast. if you are looking for 3/4 ton axles ill sell mine as i want a d60 and d 70 for lower geering, what i would sell rear 14 bolt full float gov lock front 10 bolt open warn hubs both work great and i just changed the fluid got 1 mile on the oil both have no issues.well im still planning on buying that d70 from you with the 4.56s so unless you got something we can work out i guess im gonna have to go with those for now.
