trustyrusty77
Registered Member
Hopefully this is a quick one. I have a 77 K5 with a 350/350/203. Dana 44 front and 12 bolt rear. stock gears ( 3.73s???) I have 35" LTB's on there now with a 6 inch lift. im adding a couple more inches and want to go to 38" tires. what gear ratio do you all recommend for the front and rear?
secondly, will I need to upgrade my axle shafts to something like chromoly shafts? I have a ton of experience in offroading and this sort of stuff but the knowledge stops at 35" tires and 4.56 gears. I've never ventured past that realm and don't want to start breaking axles. down here in Houston there isn't a lot of rocks but I try and stay away from mud. its a trail rig mostly but one day MOAB is in the works..
appreciate everyones feedback!
