pvfjr
What might be found under a S10 blazer? We need to replace the rear end in a 89, and there's a 85 being parted out a ways away. I'm just wondering what I might run into.
ive seen alot of 3.08s and 3.73s also. it really depends on what motor, auto or manual and if 4wd or 2wd.dyeager535 said:IIRC, the two most common ratios in the 80's were 3.42 and 4.10.
yes, ive seen quite a few of these bolts broke.you will DEFINITELY want to try and remove the axles before purchase, as the pinion shaft lock "bolt" is very prone to be broken in these, and that means you can't pull the axles out if you need to.
The G80 isn't a gov-loc in the 7.65 10 bolt. It can either be a thorsen, or an eaton clutch posi.
