I am in the process of gathering parts for a new engine build up, and I hope you guy's can answer a couple questions . The planned engine is a regular 350 small block . The block itself is a 4 bolt main,cast in 1978 ,I think it's a truck block.The block was given to me free ,from my older brother(thanks Mick).I plan on reusing the stock cast crank. I micropolished it myself with fine grit sandpaper/ solvent and a shoe lace . The crank will be magnafluxed and checked for straightness at the machine shop.I will also be reusing the stock rods.The beams will be ground smooth on the sides and polished by me and they will be resized by the machine shop and magnafluxed.Should I go with forged pistons ,or hypereutectic? should I use press fit pins? molly rings?The block will be .030 over ,it will be decked,torque plate honed, and the mains will be align honed.I plan on using tri-metal bearings. This leaves the cylinder head and cam selection.As of now I have two sets of heads,casting#461 cast in 1968 with 72 cc combustion chambers,that are bare,and casting # 882 which are complete . Which heads should I use to get the best low end torque?Although I plan calling comp cams for a cam recommendation, what cam#/specs would you guys go with?Iplan on using roller rockers. I'm building for low/ midrange torque. Edelbrock dual plane intake-Edelbrock 795cfm quadrajet,15/8 inch headers,Flowmaster mufflers. Trying to build this as cheap as possible.Wish I could find some vortec heads at the junkyard.So if some one could give me some advice on the above questions(Iknow there is a lot)it would be greatly appreciated. Let me know what you run in your 350's and also any past builds. As of right now , Iam not going to use a stroker kit-that's for next time.Thanks
