I disagree on going with Q-Jet carb. Not because Q-Jets are bad carbs, but they are "spread bore" carbs, and ALL aftermarket aluminum intake manifolds are "square bore". This means you have to use a square bore-to-spread bore adapter. This combonation is not optimal for performance.
The reason the Edelbrock Performer carb (based on the old Carter AFB) gets such a bad rap is because people slap them on with no fuel presure regulation system, and expect them to run flawlessly that way. The Edelbrock carb is very good at flowing fuel, but not metering it. People like the Q-jet because they could just slap it on, and it could regulate fuel pressure without regulators. This is because the Q-jet has four sytems: idle, off idle, main, and four barrel. The Edelbrock was designed for performance, thus it only has three system: idle, main, and four barrel. Without the Edelbrock having the "off idle" system of the Q-jet, it cannot meter fuel the way a Q-jet can. I have found Holleys double pumpers to be great for racing because of thier infinit adjustability, but tempermental to weather changes...unless you buy thier off-road carb. I have heard very good things about Holley's off road carb, but it is 3-times the cost of a standard Edelbrock Performer. Edelbrock also makes a more expesive off-road carb.
