ID Gen 6 454 and hydro 465/NP205 setup for sale
Ducshak
Registered Member
Idaho
I am going a different route and am putting this stuff up for sale. First:
454:
Gen 6 (4 bolt) block, standard bore with machine shop hone.
Hypereutectic pistons
Scat pro stock rods with floating pins
Lunati voodoo hydraulic roller cam
Comp Cams billet timing set.
Air Flow Research 265cc aluminium heads with Comp Cams ultra pro magnum roller rocker arms.
Comp cams pushrods
Edelbrock performer RPM manifold
MSD pro billet HEI distributor with MSD 8.5 wires
Lots of ARP fasteners throughout.
Billet Specialities alternator and power steering bracket set with new alternator and power steering pump
Lots of stuff I am sure I have forgot. If you need more info just let me know. $3800
Hydro SM465/NP205 setup.
Has pedals, shifters, master and slave cylinder, crossmember and SBC flywheel that will need resurfacing.
Can also choose a gen 6 BBC flywheel if you need that instead. $450
Also an option to the buyer of the transmission is a new in box Centerforce Dual Friction clutch assembly with clutch release bearing for an additional $250.
https://ck5.com/forums/attachments/img_3237-2-jpg.223094/?IMG_3237 (2).JPG
