Unless you have a stock pan - It isn't going to fit, and even then it may or may not. No LMC, appearently some Molodon pans and appearently some stock pans.
email to Kert:
Kert,
The pan I started off with was an LMC pan $40.00, I took a pipe to it to see if
"rounding the corners" would work. Then I bought a new gasket set around $40
and a $20 pan from the junk yard. Then I bought the same pan as the guy on
CK5.com for $90.00.
There is a serious flaw in your jig or just this crossmember. In addition to
the money I spent I've put over 8 hours into "swapping pans" and have had
enough. I haven't posted anything up on CK5.com nor pirate4x4 until you have a
chance to make this right.
Pics on photobucket:
http://s219.photobucket.com/albums/cc43/JoeChoat/K5/
Joe
Email I got from Kert:
Joe,
Feel free to return the crossmember for a refund or a replacement. If for a
replacement, we can attempt to bend the crossmember differently to help you
in fitting this. There are lots of things that can contribute to the
crossmember hitting the pan.
First of which, we may have made a mistake on your crossmember. With our
fixturing it's doubtful. The crossmembr tube is controled on the inside of
the shape in three places plus the notches have to line up for the larger
bushing tube.
I see you have some photos of a stock pan, have your put that pan on? It
would appear it has far more rounded corners than either fo your aftermaket
pans. I've seen pictures of the other pans but not the stock one.
Kert
Reply:
I'm severely disappointed in what should have been at most a 3 hour install and
$180.00 turned into about 8 hours of installation(s) 80 miles driving time, over
$300.00 in parts, since I cannot return the pan to Summit since my old pan now
has divots in it, and the stock from the junk yard - well you've seen it. All
this just to go to Kragen and buy there Indian $7.00 motor mount.
Joe
Reply:
Kert,
I will be returning the crossmember and no I won't be attempting a re-install.
No, I didn't take any pictures of the stock pan that fit exactly like the
Milodon, If I could have ripped the f-ing pan off without unbolting it before
running to Summit racing 1 1/2 hours away and shoving it somewhere I would have.
There cannot be that many variables, there are pre-drilled holes in the frame
and your C inserts only fit one way.
I got $159.91 back after Paypal fees etc. I did accidently keep the 6 bolts for the block - sorry.
