I did that for a while.Just do what @Deuling does and drive around without the hood![]()
That's what I did on my perkins equipped blazer there was about 2.5" between the water pump snout and the radiator, so I got 2 electric fans and put them on both sides of the snoutThe fan is mounted as high up as it can possibly go. I can try bending the mounts. I put the panel for the hood latch on. It is closer to the radiator than the upper part of the core support is. There's a little room to move before I would have to trim the hood latch panel. I need to set the hood on though to see if the radiator would hit that if I did any of this.
In the meantime, I called the radiator company and they said I could send back the fan and shroud and they would make me a dual fan shroud with staggered fans, then just charge me the difference. So something to consider
I sure hope so. October will be here before I know it.Will you be done with this for iron Invasion? Little further to drive this year...
You heard they moved it to the quad cities, right?I sure hope so. October will be here before I know it.
Yeah I did. Much bigger venue. Hopefully people are willing to make the trek. Or new local people go to it. From what I heard, it's two buildings and one of them is the size of all the buildings they used at Woodstock location, combined. So plenty of indoor space in case the weather is terrible, which it is practically everytime lol. I heard part of one building is gonna have some 70s stuff like choppers, custom vans, and street freaks. Which I'm excited for that cause I dig that stuff too.You heard they moved it to the quad cities, right?
Superior Radiator out of MichiganIs that a Champion Radiator?
I would say that real custom tuning can't be done in a single day by definition. You have to hit 200 degree underhood temps, -40F cold starts, low and high altitude and every load/RPM combination possible, figure out the right transient adders from MAP/MAF etc. Now when you start with some stock LS file, a ton of that work has already been done by the professional engineers, so you only have to account for what you've changed from the stock setup. But in some circumstances people are quick to consider tuning to just be tweak the fuel and spark tables, which is a lot easier than tuning all of the MAP/MAF/temp transient stuff. Granted, a summer cruiser is easier to get running acceptably than a year-round multi-purpose DD.Yes you have to have IAT and cold start tables. 40 hours is with changing tons of variables, cam, heads, intake etc. You could have it running pretty good in several hours, but not meet every single condition possible. 40 Hours is getting everything dialed, and running as close to stoich as possible. For Ryan's case it shouldn't take much time as the factory cam and heads are still in place.
I have a 59 GMC that is getting an LS swap as well and have a couple of questions. Was there a specific reason you chose the ICT belt bracket kit that you did? Also, why did you go with the electric fans over the traditional fan? Thanks in advance for the insight.
