bp71k5
3/4 ton status
Today, I removed the electric fans and went back to the mechanical. On the surface streets, temp stayed at 185. At an extended idle, it crept up to 205, but cooled right down when I increased the RPM. The Flex-a-light 295 seems to work great at idle and great for the AC, but seems to restrict airflow at higher speeds.
I was going to hit the freeway but another gremlin jumped up. My entire AC system shut off and I don’t know why, but it came back on a couple minutes later, and then the engine shut off at two red lights as I came to a stop. It wouldn’t restart for about 3 minutes but then fires back up. I’m wondering if the K&N filter oil seeped or got in the throttle body after I cleaned and re-oiled it today. It idled in the driveway for 15 minutes with neither issue coming back.
I need a blend of the mechanical fans efficiency at highway speeds with that of the electric fans for AC and idle temperature control at super low speed when it’s over 105.
if your shroud with the mechanical fan doesn’t have some flaps to let air flow through at highway speeds, that might help out.
