mlrtyme
Registered Member
Just purchased the 10205 Painless kit for my newly acquired 84 Jimmy and plan to rewire so I can toss the hacked up factory harness in the garbage. I'm familiar with rewiring vehicles so the obvious items (good grounds, measure 3 times before cutting once, lightly clean the connections on the printed circuit board, don't put the tach lead onto the gas gauge power feed post
) are a given. However, what K5-specific items should I look for?
Here's what I have so far:
- Tailgate: Make sure that the power window safety switch is disassembled and cleaned. Check the power cables for corrosion and ground and repair where appropriate (with proper solder and heat shrink tubing)
- Doors: Plan to remove each power window/lock switch and clean terminals
- Dash: clean terminals for tailgate window switch
- Chassis: Check fuel sending unit for proper ohm operation and good ground
Anything that anyone else has run into that I should be aware of before diving in this 3 day weekend to start?
Thanks in advance...
MLRTYME
) are a given. However, what K5-specific items should I look for?Here's what I have so far:
MLRTYME
