B
Bohemian
Guest
1982 K5 Blazer with stock GM 10 Bolt Front, Open Differential, Manual Locking Mile Marker Hubs. 28 Spline Axles. NP208, TH400.
I can spin the drive shaft by hand with front wheels off the ground.
Spinning either wheel while front axle, wheels are off ground turns drive shaft. With or without hubs locked.
I'm unable to turn driveshaft by hand with wheels on ground while hubs are unlocked or locked.
Is this expected or am I missing something obvious?
Thanks in advance.
IF this is in wrong forum, its because this is the only forum my account can post to at this time... Subtle hint moderators :-)
Thanks in advance.
