Wrench
Turbo in great shape, a little oily but no end play on the shaft, both exhaust manifolds and both upper and lower F-code intake manifolds (F-code is the TD equivalent of the J-code 6.2's). Also will include the oil feed and oil drain lines, but the crossover pipe is not included. The stock one interferes with the front driveshaft in the pass. drop trucks, and it's relatively cheap to get one custom bent by a muffler shop.
I'd like $300 for the set, and again, I'm driving to Michigan end of the month so I can take it along if anyone wants to meet me. I'll be going through MT, ND, MN, WI, IL, IN, and MI, then up to Toronto.
.... although shipping would probably be a kick in the nuts.
