Yes I didchange the rear housing clocking.
Yes I did
Thought about a spacer to move the crank/water pump pullys and serpentine brackets out a little, so I googled it, and found the crank pulley spacer, I was looking at the 1/4 inch. anyone ever did this?anyone know of a kit to convert my serpentine GM CS alternator from rear positive post to side battery post?
Battery positive post touching valve covers
On my '90, the plug faces outward to the left fender, which is how I have found several of them to be. That would put the charge post up from where it is. I don't know if it would give enough clearance due to the valve cover shape.Yes I did
You can buy a side-post alternator, but I don't know if anybody sells a kit to convert. That might be simpler than finding reliable spacers for everything on the belt. Or possibly different valve covers. It's always been tight on SBC. I know mine is close but it's never been a problem.
