Is it possible for there to be an issue with the hydro boost that would apply the brakes? An internal leak of some sort that would push the master cylinder without you having touched the brake pedal itself?
My crew cab brakes are applying themselves without any input on the brake pedal.
It gets to the point where you have to start dropping gears. When you finally give up and pull off the side of the road, the brake pedal travels much further than is normal. Hubs are hotter than they should be on both sides, front axle only.
This happens while you are at cruising speed with no pedal input. They simply start grabbing.
Everything else turns freely. Jack up the front end and the tires won't turn. Give it some time and they free up again and roll smoothly.
