GMT800/900/GMTT1XX wheels
muddybuddy
1 ton status
Northern, VA
I seem to recall the backspacing/offset is a bit higher, and i believe the center bore is too small for the front hubs on square? Found some 17’s i like, but fairly certain they cant/wont work. Can always enlarge the center bore. Change out the center caps, aiming for a current rally in 17” since nobody makes them
Yes center bore on these wheels will be too small. I've heard you can create enough clearance with a grinder and just use the wheels as lug centric though.
