Going back stock
Jay Bird
South Carolina
Have a 89 blazer and want to go back to stock suspension. JC Whitney has two front springs, a 1850 lb 2 leaf pack or 2250 lb 3 leaf pack. Which one should I get? I have a 350 engine. Rear is a 4 pack that they have for sale and rating of 1350 lbs. does that sound right?
Thanks,
Jay
I bought some CUCV springs and they work great. Unfortunately I don't know the load rating, but I would go for the higher load rating in case you want to out a winch and bumper on the front at some point
I don't know what to recommend for the front. You could always buy the heavier springs and take out a leaf if they are too stiff. I bought a set of their rear springs to replace mine that had been tweaked, and I thought maybe they were a little soft. If I don't change to something else, I think I will add a leaf to them.
I just bought a set of Bilstein HD which are supposed to be pretty good. I've also read good things about the Monroe Gas Magnum if you're looking for a budget solution.
I don't know if your interested but I have a set of stock front leafs out of my 91 k5 with 89,000 miles on them. I also have newer shocks, the k5 rode super nice with this setup, but I'm currently swapping 1 tons so this stuff is for sale. I'm located in NJ.
My dad makes frequent trips to north Carolina to jersey if your interested pm me.
Why don't you hit the junk yard and pick up some front and rears off another truck? Unless you want to just go all new....
I have had both the 2 leaf and 3 leaf front springs in a few 4x4's,the stock ones look "sagged" due to a negative arch,which is how they were designed..the 3 leaf versions handle a plow better,or weight from a heavy winch or bumper,and dont seem to degrade the ride quality all that much...I'd say go with the 3 leaf ones.......................................................but my '82 K2500 diesel has only 2 leaf front springs and it handles the plow OK,and rides pretty nice for a 3/4 ton pickup.............it only has 4 or 5 leafs in the rear too,so it doesn't ride like a dump truck...................................................................................................I had some 4 leaf rear springs in a '75 K5 I had ,that were practically new ,someone was going to toss them after installing a lift kit...the truck originally had some 8 leaf rear springs,but one snapped at the main leaf,and I needed springs "now",so I grabbed the freebies up and put them in--I was concerned they would be too soft or saggy compared to the 8 leaf ones,but they had a lot more arch than the 8 leaf ones,and it actually sat higher up and rode much better with the 4 leaf ones...and I didn't notice it sag much the few times I did load it up with firewood.....
Thanks guys! I think I'll go with the HD fronts and see how the back sits before buying new ones.
