A few years back I tossed a rod and it ate up the crank . So I tried in vain to get a used crankshaft with no luck . 2 years ago I lucked into a complete 6.2 . Well I switched jobs and never could get to the swap . I had it in the back up my pickup(covered up of course) Then I lost the keys .Then I spent another year getting keys made . Now the engine is in my shop and had no water in the engine . Now the question sorry so long winded . The engine I have is out of a 3/4 ton truck with no egr . Thinking about my old engine and when I dropped the pan the cylinders walls looked great . The only metal is from the rod going . Now I wondering if I should rob the crankshaft and rod and just fix my original engine . Is there any advantage to using the replacement engine for my Blazer . I have never heard this engine run and it came out of a old farm truck . I have a non egr intake on my original already . The heads different ? I would like more naturally instead of installing a turbo. Thanks
