dbreid
I have a 1984 K30 Factory BigBlock (which means it has the different motor mounts, and the pain in the butt crossmember for the One Ton Frame). My crossmember clearance to the oil pan is crappy and my crossover is close, so I am installing one of ORD's Crossmembers, and am installing new poly motor mounts from Kurt at DIY4x.
So, while I am in there basically doing all the hard work, I thought this might be an excellent time to upgrade my Oil pan to a more offroad friendly one, as well as stick in a amtching, better oil pump.
Does anyone have any recommendations? I looked on Summit and there seem to be a lot of choices, and I was looking for some thoughts from you all.
Also, it seems that the one piece gaskets are better? Any thoughts there?
Lastly, I don't really care about color/bling, etc, and I am open to anything that isn't Chrome.
Thanks!
-Dan
Thanks!
-Dan
