It's all added on. I yanked an under-hood fuse box from a mid 90s F150. It is mounted on the passenger fender well.
When adding the fuse box, I believe that I shifted the main distribution point to the fender, since there is a large chunk of current pulling from there. The firewall buss by the brake booster is about 6feet of 8awg wire downstream from the fuse box. It goes BAT->new fuse box (powering new accessories) -> firewall buss. Should I move that wire to the fuse box then?
Thanks ryoken, for helping answer too
Well, now there is power pulled from two points so to speak. Ryoken says the alt wire hooks to firewall buss. Alt current flows to the F/W buss and goes to the truck, if you left those wires on there, and back thru the 8 awg to the maxi fuse and then to the batt. That much current thru the 8 awg is going to result in a voltage drop before it gets to the maxi fuse. I would upgrade that wire to a 4 gauge or move everything off that F/W buss to the maxi.
gotta keep the CG boy's happy and I like to sleep at night...
