Goodbye Carburator!
Looks good. You might try adjusting the TPS a little to deal with some of the flat spots. Mine seems to get them too sometimes and once it was because the TPS was off some.
Unless you get a baffled tank don't run below 1/8 tank on the street and 1/4 on the trails. You will stop getting gas on hillclimbs, offcamber, corners, etc, and that isn't good for the fuel pump.
Harley
Hmm, I'm officially a little nervous about Comp Hill now. /forums/images/graemlins/histerical.gif I would love to do the same to my 406 and add a little blue bottle to it. I want to talk on the phone some time and get every detail! /forums/images/graemlins/deal.gif /forums/images/graemlins/grin.gif
Yours too! Wanna trade? /forums/images/graemlins/crazy.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/peace.gif /forums/images/graemlins/pimp1.gif
Hah.. My 1972 K5 meets 90's technology... /forums/images/graemlins/thinking.gif /forums/images/graemlins/ignore.gif The check engine light i have now is still trippin me out. /forums/images/graemlins/rotfl.gif
[/ QUOTE ]I will trade you gas mileage...... /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
So far it looks like I picked up a couple miles to the gallon over my carburator easy. This thing runs AWSOME. /forums/images/graemlins/peace.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/peace.gif
My VSS showed up today...
I adjusted the idle screw up just a bit when i first fired it up to keep it running... so it was idling a bit high driving it around, I turned down the idle and then it wanted to almost stall out backing out of a parking space a few times.. Coming to a hard stop it will chug a little and then the idle will come back up, but hasn't stalled on me yet.. This Mechanical VSS should take care of that.
If the Injection setup didn't give me more HP or torque, the emblem sure will. /forums/images/graemlins/thinking.gif /forums/images/graemlins/blush.gif
YYYYYYYYYEEEEEEEEEEEEHHHHHHHHHHHHHAAAAAAAAAAAAAAAAAAAAMPFI /forums/images/graemlins/peace.gif
Sure can't wait for my day...........to be INJECTED!!!!
/forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/waytogo.gif
VSS was from www.streetandperformance.com same place i got my wiring harness and prom from.
The mechanical VSS runs about $120, it puts out 4 pulses per revolution and screws onto the t-case in between the speedo cable. /forums/images/graemlins/pimp1.gif
As long as his speedo is correct now then it will be ok otherwise it will still do weird things. Ask me how I know. I think Ryan told me his speedo is accurate now though with his tire and gear combo.
Yep, my speedo is close. slightly too fast with my 35's (probably better too fast than too slow?)
and with my 38's on my speedo is about dead on.
