I looked at the FAST setup and it was cheaper to buy the equipment to burn chips. I'm completly setup to read and burn my own tbi chips for the 7747 ECM. It might not be as awesome as your setup but I like it. Watching your thread to see your results....
I don't really think the FAST setup and the standard GM TBI are comparable. Yeah, they are both throttle bodies, but that's about it. TBI is a low pressure 2 barrel with injectors outside the throttle body in the air cleaner. The FAST system uses high impedence high pressure 65 psi injectors UNDER the throttle plates more inside the intake, with a 1000 CFM 4 barrel throttle body minimum. Also, with the same EZ-EFI computer, you can also tell it you want 2 throttle bodies, or tell it any injector size, and any number of injectors (4 multiport intakes), or any number of cylinders (different engines), or fuel pressures, etc. With the right fuel system and injectors, you can support 200 hp or 1200 hp. The same computer does it all.
With that said, I think it's awesome you can burn your own chips, props to you for that. Not many people try to do their own tuning.
I started mine for the first time this weekend, and I drove it for the first time last night. So far I love it, lots if live data if you leave the handheld unit hooked up (not necessary). Can change A/F ratio on the fly if you want while monitoring all the parameters. So far so good.
By the way, I love your sig line!
