You can still do all that with the old 7747 in the chip.Hey Mastiff,
Since I am gone from home a lot, I still don't have my project completely tuned yet. But I think it will get there.
I'm with you, I didn't want to invest in a 25 year old technology either. Yes TBI can work well, for all you who have done so.
But since you had a carbed setup to begin with, first off you should stay carbed. You can get a wide band 02 sensor and really tune your carb.
There is no power advantage to EFI. It was mainly developed to control emissions, they do start better and run better during startup conditions and in cold weather.
I did look at some of the other EFI systems from Edelebrock and Howell and the TPI. But I wanted to use a cam with less vacuum capability than traditional efi systems and I wanted something that I could change engines with and still be able to run it. Like when I get my 400 sbc I can just bolt this system on it and it will run that too.
So it is pretty much plug and play, especially since you don't have an overdrive, or computer controlled ignition.
I had to put in an MSD and I am just about done with my overdrive lockup system.
The biggest thing is the FAST EZ efi, comes set quit rich, and I have had some trouble fouling my plugs, because I had the idle set too rich. But after a quick call to the speed shop that sold it to me I got that straightened up. Also you cannot have any air leaks in your exhaust. Which is also true with your TBI, but even more so with a wide band O2 sensor, since it commands the tuner to change your af ratios instantly.
So to answer your questions, yes it is plug & play. But you do have to answer the setup questions so it can calibrate itself. You'll have to put in a high pressure fuel pump. But you can use your stock distributor already.
PM me if you have any other questions.
Good Luck
My AFR goes to 12.5 to when I hit the throttle past 60% and enter PE (Power Enrichment. There are also Hi Way mode settings built in but turned off do to emissions. Problems with tuning a GM ECM this way is the catalytic converter does not like it and gets to hot... but mine fell off. When I enabled Hi Way mode I gained 15% MPG...
). It just flashes the memory using a computer. And I expect BobR will help you get things going within reason. I E-mailed him to find out how much hand holding is included with a purchase.
Don't need a new laptop just any old one that runs and I think all equiptment can be had for $150.
