anyone have stock specs for a GM Goodwrench 350 crate motor? circa 1981 with 4 barrel Q-jet carb. hp & torque @ rpms? I heard it was slightly higher than the regular 350 (which isn't saying much
)I want to say my 91 stock GM 350 is under 200hp, like 190hp. So i doubt a crate from the early 80's would be more than that.
The GM Goodwrench replacement TBI 350 is rated at 210HP and 300lb-ft at the flywheel
There are 2 LO5 TBI motors. The 210 hp 2 bolt main in cars and 1/2 ton trucks
and the HD 190 hp 4 bolt main in 3/4 and1 ton trucks. Most C/K2500 have the 190 Hp
Goodwrench makes both types.
