Blade walk is my biggest gripe with the portaband/SWAG setup. It would be cool if someone made a guide block for it.
I had the swag table but I wasn’t impressed back then. Things have changed and I’d probably use it a lot nowadays.
I’m probably gonna cancel my order though. Sometimes my shear brilliance amazes even me.
I only cut straight with it mostly. If you cut curves the leverage of the work piece spreads the bearings out and then the blade goes crooked. You can replace the bearing/guide assembly from Milwaukee and then its pretty straight again, but not perfect.Blade walk is my biggest gripe with the portaband/SWAG setup. It would be cool if someone made a guide block for it.
It’s being used to rip small square tubing longways into little channels. The material doesn’t hit the clamp.I'd be afraid to use it like that, the material won't go in flat and it would want to bind up on that clamp and pinch the blade. Plus, I have a big foot switch to shut off my 120V saw, if something happens on that one how will you shut it off?
I'm glad I'm not the only one who has a hard time cutting anything straight. I feel like the blade walks or twists on me and I get garbage cuts if I use the miter as a guide. If I free hand it I can adjust the work piece as the blade shifts and get decent results. Either way still cleaner and quieter than a chop saw.Blade walk is my biggest gripe with the portaband/SWAG setup. It would be cool if someone made a guide block for it.
How much to fix that?
Martin
